Vent Overheating
October 30, 2025 at 3:10 a.m.
Dan from South Carolina asks: Because I live in a double wide mobile home (2000), I only have box vents on the roof. However, when I shoot the decking board, on a 89 degree day the decking board area was around 130 degrees. This made me believe my soffit vents are not working or blocked. Upon inspection (with my borescope) I notice the insulation is just laying there. So what I want to do is open up on the soffit vents and put some PVC pipes up there. A little bit of air is better than none.
Below is what our roofing expert John Kenney with Cotney Consulting Group had to say in response to your question:
Dan, you’re right that proper attic ventilation is critical—especially in manufactured homes, where shallow eaves and compact attic spaces often limit airflow. A roof deck temperature of 130°F on an 89°F day clearly shows heat is trapped, shortening shingle life and increasing cooling costs.
From what you described, your soffit vents are likely blocked by insulation, which is a common issue in manufactured homes. Before modifying the soffit, I’d recommend checking with your local roofing supply house to see if they have a better product you can use instead of the PVC piping.
If your existing soffits are painted shut or have minimal openings, it’s also worth upgrading to a continuous vent strip to improve airflow. Combined with your existing box vents, this will create a balanced system—cool air entering low, hot air exhausting high.
TopShield (SRS) - Banner Ad - Ice & Water
