Tar Paper and Asphalt
November 16, 2026 at 3:19 p.m.
Beto from Florida asks: I have a photo of a roof that was just completed in metal, but I noticed at the bottoms there’s two areas like a basin where the water all meets from the metal and flows off the roof which looks like tar paper. Now metal has a warranty a lot higher than tar paper so is this the right type of job that they completed properly or should that be some type of metal?
November 16, 2026 at 3:20 p.m.
Hello Beto,
Below is what our roofing expert John Kenney from Cotney Consulting had to say in response to your question:
Beto, based on the photos, the metal panel installation appears clean and well executed aesthetically. The panels look straight, the layout appears consistent, and nothing visible immediately suggests poor workmanship. However, a photograph cannot tell us how the panels were fastened or whether all the transition details meet the metal roofing manufacturer's requirements.
The areas you are calling “tar paper” are where I would want more information before deciding whether the installation is right or wrong.
That material may not be conventional roofing felt at all. It could be an SBS-modified bitumen membrane or another roofing membrane designed for areas where water concentrates or where roof geometry makes metal panels difficult to install properly. If it is the correct membrane and it was installed according to the manufacturer's requirements, there is nothing inherently wrong with using a membrane in those locations.
What matters is the complete detail.
Those areas appear to collect and move a considerable amount of water coming off the metal roof. I would want to verify what membrane was used, how it was installed, and how far it extends underneath the metal roofing.
The transition between the metal and the membrane is especially important. The underlayment beneath the metal roof should be incorporated into that transition so water is directed onto the membrane and cannot work behind or underneath the roofing system. The exact lap distances, fastening, flashing, and termination requirements should follow the manufacturer's approved details for the products being used.
I would also want to confirm that the membrane itself is approved to remain exposed in that application. Some products that look similar are underlayments intended to be covered, while others are finished roofing membranes designed for long-term exposure.
The warranty question is also worth asking, but I would not compare the metal warranty directly with what appears to be “tar paper.” They are different components performing different jobs. The better questions for the roofing contractor are:
  1. What exact product was installed in those drainage areas?
  2. Is that product approved for long-term exposure?
  3. How far does the membrane extend underneath the metal roof?
  4. How is the metal roof underlayment tied into the membrane?
  5. Can the contractor provide the manufacturer's detail used for this transition?
  6. What warranty applies to the membrane areas and the transition between the two roof systems?
I would not recommend replacing those areas with metal simply because the rest of the roof is metal. Depending on the roof geometry, forcing metal into a low area or complex drainage transition can create more problems than using a properly designed membrane system.
Based on the photographs, I do not see enough information to say the installation is improper. I would ask the contractor to identify the membrane and provide the installation detail used. Once those two items are confirmed, you will have a much better answer about whether the roof was completed correctly.
Thank you for using AskARoofer! Find more resources to answer your roofing questions here: podcasts, articles, previously answered questions and more!
SRS - Banner Ad - Supplying the pros, job after job
