Rooftop Deck
May 6, 2026 at 12:06 p.m.
William from Washington asks: Hello! I recently purchased a house in Seattle with a rooftop deck that uses IB Deckshield as its waterproof membrane. I want to start adding PVC interlocking deck tiles and turf (with PVC drainage mats underneath) to the roof, but I'm worried the feet from the tiles and drainage mats may damage or puncture the IB Deckshield membrane. The heaviest object that will go on top of the turf/tiles will be a 3-seater sofa. Should I be adding a protective mat underneath the deck tiles and drainage mats, or is the waterproof membrane strong enough to withstand it? Any guidance here would be greatly appreciated.
Below is what our roofing expert Jim from RoofSmart had to say in response to your question:
Hello William,
Congratulations on the new home! Protecting your waterproof membrane is a smart move. Maintaining the integrity of a rooftop deck's "hidden foundation" is essential for long-term home health.
To address your concerns about the interlocking deck tiles and the potential for punctures:
  • Pressure Distribution: The "feet" or grid patterns on the PVC tiles and drainage mats you linked cancreate localized pressure points. A 3-seater sofa adds concentrated weight that could accelerate wear or indentations over time, especially during Seattle’s wet and freeze-thaw cycles. I have seen this create punctures opn other homes.
  • Essential Airflow & Drainage: One of the primary causes of membrane failure is trapped moisture. Your plan to use drainage mats is a great start—maintaining 360-degree airflow ensures both the tiles and the membrane dry uniformly, helping to mitigate mold or rot beneath.
  • Serviceability: A major advantage of modular tiles is that they are easily "pop-up" serviceable. This allows you to inspect the underlying membrane or clear debris without a major construction project.
My Recommendations for Your Setup:
  1. Yes, use a Protective Layer: I highly recommend adding a slip sheet or protective mat (like a crumb rubber mat or geotextile fabric) between the IB Deckshield and your tiles. This acts as a cushion to distribute the load from the sofa and prevent direct abrasion.
  2. Maintain Drainage: Ensure your overall roof slope remains clear and that the mats don't block scuppers or drains.
  3. Load Management: Consider placing larger rubber pads specifically under the legs of the sofa to further spread that weight.
RoofSmart Resources for Your Project:
I know you plan to do all the work yourself, and that's great. We handle many IB Deckshield-style decks in the Seattle area. You might find these specific guides from our blog helpful as you plan the install:
If you’d like us to do a professional walk-through and check the condition of your membrane before you cover it up, feel free to reach out. It’s always better to ensure that foundation is 100% secure before the furniture goes on!
Westlake - Banner Ad - US Tile Concrete & Clay Roofing (AAR)
