Ridge Vents
October 28, 2026 at 3:17 p.m.
John from IL: Can I have a ridge vent installed with only having gable vents towards the top of my gable ends. I currently do not have soffits.
October 28, 2026 at 3:19 p.m.
Henry Staggs from The Arizona Roofer says: Yes, it can be installed, but on its own it won’t do what you want, and it can cause problems.
Ventilation works by bringing air in low (intake) and letting it out high (exhaust). Hot, moist air rises, so that low-to-high flow sweeps the whole attic. If your only openings are gable vents near the top and you add a ridge vent, the gables become the intake. Air takes the shortest path from the gables out the ridge, and the lower part of the attic near the eaves stays stagnant.
In Illinois that matters. A ridge vent without enough intake can pull warm, moist air up from your living space. In winter that moisture condenses on the cold roof deck, which leads to frost, damp sheathing, mold, and can make ice dams worse.
Not having soffits doesn’t rule out good ventilation. You can add intake at the eave with an edge intake vent installed under the first course of shingles, or with intake vents installed low in the roof. Once you have proper low intake and a ridge vent, the gable vents are usually closed off so they don’t short-circuit the system. Also make sure the attic floor is well air-sealed and insulation isn’t blocking any intake.
If you don’t want to add intake, you’re better off leaving the gable vents as your system rather than adding a ridge vent that has nothing to draw from.
Metal Roofing Alliance (MRA) - Banner Ad - Solar
