Need Advice on Flat Roof Flashing Against Concrete Parapet
« Back To AskARooferHi Everyone,
I’ve got a tricky situation with an older commercial building that’s got a concrete parapet wall meeting a flat roof. The existing flashing has failed where it meets the concrete, and I’m trying to figure out the best approach for the replacement.
A concrete contractor I know suggested using a polyurethane-based sealant for better adhesion to the concrete, but I’m not sure how well that will hold up long-term compared to traditional flashing methods. The building goes through some pretty harsh freeze-thaw cycles here, so durability is key.
For those who’ve worked with similar setups, what’s been your most reliable solution? I’m debating whether to cut into the parapet for a proper flashing install or if there’s a good surface-applied alternative that will last.
Thanks for any seggestions!
You're right to be cautious—this is a common failure point on older commercial roofs, and your decision now will affect long-term watertightness, especially in harsh freeze-thaw climates.
- It creates a mechanical termination, which lasts longer than surface adhesion.
- Flashing can expand and contract independently of the wall, reducing stress on sealant joints.
- Once installed, the reglet can be sealed with a compatible polyurethane or silicone to provide extra moisture protection.
- Mechanically fastened to the concrete
- Sealed with a high-grade, UV-stable polyurethane or silicone sealant
- Backed by a compatible flashing membrane beneath it
