Low Slope Roof Leak
« Back To AskARooferRod from California asks: I have a torch down roof on a low slope shed roof that is about 15 years old. I found some rot in a facia board, indicating a leak. The leak appears to be on the edge of the roof where it meets the metal drip edge. I would like to know if I can heat the torch down roof material and roll it back about a foot along this edge, replace the facia board and then re heat the torch down? Would I need an adhesive between the metal and the roofing material? If so, what would work best? Thank you.
Torch down roofs are done in layers. However, most torch down roofs that I have seen on residential homes are made up with a base sheet and a cap sheet. If your torch down roof is only a base and cap, then you are looking at a roof replacement, not a repair. That is because the life expectancy is about 10 years. The surface will look like it's alligator skin texture- rough and possibly cracking.
Below is what our roofing expert John Kenney with Cotney Consulting Group had to say in response to your question:
Rod, I wouldn’t recommend using a torch on an older structure, especially one with a wood deck and fascia board. The fire risk increases significantly due to the dry, aged materials and potential hidden gaps near the edge. Instead of reheating and rolling back the old membrane, which may not re-bond reliably, it’s safer to carefully cut back the material, perform the fascia repair, and then patch using a cold-applied modified bitumen system or self-adhering membrane. If you must seal it to metal, use a compatible adhesive or flashing cement rated for metal-to-membrane applications. You’ll preserve roof integrity without putting the structure at risk.
