Dark Spots on Roof
January 23, 2026 at 6:44 p.m.
James from Illinois asks: I have dark stains at the bottom of downspouts after rain, from my upper roof to lower roof. I assume that is because I can't get to the upper roof to clean the gutters, and dirt is washing down. I will eventually get a bid to clean the upper gutters. But I'm also getting the same dark staining in an area where there is no downspout. See photos with the red arrow, about 8 hours after rain. Any idea why this would be happening?
January 23, 2026 at 6:47 p.m.
Hello James,
Below is what our roofing expert Sarah with Raincoat Roofing had to say in response to your question:
Watch Sarah's video response here
February 3, 2026 at 12:11 p.m.
Hello James,
Below is what our roofing expert John Kenney with Cotney Consulting Group had to say in response to your question:
James, your assumption about the staining below the downspouts is correct—some of that discoloration is runoff carrying dirt, roof granules, and organic debris from the upper roof and gutters. When gutters aren’t regularly cleaned, that dirty water concentrates at discharge points and leaves dark streaks on shingles and siding below.
What’s more telling, though, is the staining you’re seeing where there is no downspout, like the area you marked in red. That points to a different mechanism. In those locations, the staining is most commonly caused by water shedding and slow drainage along the roof surface, not gutter overflow. When rainwater moves slowly across asphalt shingles—especially on shaded elevations—it can carry asphalt oils, fine granules, and airborne contaminants. As the surface stays damp longer, those materials deposit and create dark streaking, sometimes within hours after rainfall.
Other contributing factors I see in situations like this include:
  • Minimal slope or drainage concentration at the roof edge
  • Shingle aging, where asphalt bleed-out becomes more visible
  • Shaded conditions, which delay drying and allow staining to develop more clearly
The good news is this is usually a cosmetic issue, not a leak or structural problem. Cleaning the upper gutters will help reduce staining at the downspouts, but it won’t completely eliminate staining caused by natural runoff patterns on the roof itself.
Bottom line: the downspout staining is debris-related, but the staining away from the downspouts is typical roof runoff and shingle aging behavior. If it bothers you visually, a professional roof cleaning using manufacturer-approved methods can improve appearance—but it’s not an urgent repair issue.
TopShield (SRS) - Banner Ad - Ice & Water
