Bird Stop Holes During Rain
June 9, 2026 at 6:33 p.m.
Casey from Florida asks: I just had new tile roof installed. When it rains water comes out faster through the bird stop holes than shedding off of roof. Water is getting under the tiles
June 9, 2026 at 6:34 p.m.
Hello Casey,
Casey, some water entering beneath a tile roof is actually normal. Unlike asphalt shingles or metal roofing, most tile roof systems are designed as a water-shedding system, not a completely waterproof surface. Wind-driven rain and small amounts of water can get beneath the tiles, which is why the underlayment is the primary waterproofing layer.
What concerns me is your description that water appears to be coming out of the bird-stop openings faster than it is shedding from the roof surface. Bird stops are designed to keep birds and debris from entering beneath the tiles while still allowing drainage and airflow. During heavy rain, it is not unusual to see some water exiting through these openings, but excessive flow can indicate a problem.
Possible causes include:
  • Improper tile installation or alignment
  • Inadequate headlap or side lap between tiles
  • Underlayment drainage issues
  • Excessive water is being directed beneath the tiles from flashing or valley details
  • Roof slopes or drainage patterns that are causing water to travel under the tile system
The most important question is whether water is making it past the underlayment and into the structure. If there are no signs of leaks, stains, or moisture inside the home, the system may simply be managing water differently than you expected. However, because the roof is new, I would have the installing contractor inspect the affected areas and verify that the tile layout, flashings, bird stops, and drainage details were installed in accordance with the tile manufacturer's requirements.
Some water under the tile is normal. Large volumes of water exiting through bird stop openings are not always a problem, but on a newly installed roof, they deserve further evaluation. I would document the condition with photos and videos during rainfall and request an inspection from the installing contractor to confirm the roof is performing as designed.
